Re: '37 B oil pump question
Mark
04-26-2000 17:14:40
There is a shim gasket on the bottom of the oil pump under the plate with 4 bolts. That gasket normally blows out and causes the oil leak you are talking about. The gasket is available from John Deere. The part # is B246R.Remove the 4-5/16th inch bolts on the plate and you can replace the gasket. You will want to be careful as the oil pump gears will drop when the plate is removed. Will probably need to remove the crankcase cover to align the oil pump shaft to the coupler when pushing the shaft back up.Maybe need a good friend to help unless you have extra long arms. Not too tough of a job though.
