Cannot maintain throttle position on 52 JD M
Jeff
05-03-2000 07:49:03
I have a 52 M that will not maintain throttle position.
The throttle lever can be moved to increase speed, but will not stay in the set position, it goes back to idle.
This just happened recently. It has worked fine until now.
I have noticed that there is only one spring on the linkage and that is attached to what I assume is the governor. Is there another spring required or an adjustment that can be made to maintain throttle.
Any help appreciated
