Model B Rod Torque
Jim Anderson
05-31-2000 09:12:18
Does anyone know the torque value for the rod bearings for a 1950 Model B? Also the 1st gear cluster shifter arm is broken. Which side does it come out - clutch or flywheel side?
Thanks for your help.
Clyde Scott
05-31-2000 13:06:57
 Re: Model B Rod Torque in reply to Jim Anderson, 05-31-2000 09:12:18
Jim:
The rods should be torqued to 75 Ft.Lbs. I assume this is where the piston rods meet the crack shaft.
more data is avaliable at :>Link
As>Link for the shaft.. The manual tells us to remove the left side bearing by driving the shaft with a mallet until it is removed and then the shaft should come out.. I have always removed that shaft from the top after the steering pedistal and the shifter forks have been removed.
hope this helps..
Clyde Scott - Moultrie, GA.
Jim Anderson
06-01-2000 09:11:23
 Re: Re: Model B Rod Torque in reply to Clyde Scott, 05-31-2000 13:06:57
Thanks for the info.
