1010 sleeve platform
ret
06-12-2000 18:16:58
tore the old girl down, and the sleeve insert was shot. Now, after I get it cleaned up and am ready to insert the new one, any suggestions as what if anything would be the best kind of sealer to put on the rubber rings at the bottom. I can see why they had a leaking problem. Any suggestions as to coating any of these sleeve and head gaskets will be deeply appreciated. I want to make sure it is sealed tight. Thanks a lot, your input really has helped me in the past.
joe
06-13-2000 04:29:56
 Re: 1010 sleeve platform in reply to ret, 06-12-2000 18:16:58
i installed the platform on my 2010 diesel about 3 months ago. i did a real good prep of the sealing surfaces (using a small wire wheel on a pneumatic die grinder). then i just used o-ring lubricant (like the john deere manual suggests) to lube the o-rings. then i slowly lowered the platform into the block, making sure it was straight the whole way down. now i no longer get water in my oil. good luck. joe
ret
06-13-2000 12:51:06
 Re: Re: 1010 sleeve platform in reply to joe, 06-13-2000 04:29:56
joe, did you use any sealer on the gasket surfaces under the platform?
Joe
06-13-2000 19:07:29
 Re: Re: Re: 1010 sleeve platform in reply to ret, 06-13-2000 12:51:06
yes,I used the copper-based, spray-on gasket sealer made by Permatex. I sprayed both sides of the gasket. I also used this on the head gasket. Good luck!
