1949-50 john deere A all fuel
jd puller
07-04-2000 08:55:48
did john deere ever make an all fuel late A. I am talking about the A's with the pressed steel front frame. I have located one but don't know if it is original. it has the all fuel manifold, two gas tanks and it is a late A built in 1950 i think. how many were made? any help would be greatly apriteated.
al
07-04-2000 09:01:42
 Re: 1949-50 john deere A all fuel in reply to jd puller , 07-04-2000 08:55:48
yes they made them,check the blue column to the left and you should find all the info you need.
Nate
07-04-2000 15:30:44
 Re: Re: 1949-50 john deere A all fuel in reply to al, 07-04-2000 09:01:42
They also made late "A's" with two tanks but they were gasoline only. Always check the carb. and manifold. Serial number range of 655572-666728 had an extra tank that were gas burner's. Farmer's wanted an extra fuel to get them thru the day. 1947 thru 1952 they produced 16,015 regular model "A" all-fuel tractors. AH, AN, AW is a whole different story.
jd puller
07-06-2000 15:53:28
 Re: Re: Re: 1949-50 john deere A all fuel in reply to Nate, 07-04-2000 15:30:44
i relize that i must chech the carb and manifold. i am not totaly stupid. the tractor is and all fuel model A with a pressed steel frame and 6 speed trani. I think the year of it is about 1950-1952.
duke
07-07-2000 17:25:02
 Re: Re: Re: Re: 1949-50 john deere A all fuel in reply to jd puller , 07-06-2000 15:53:28
I have a 1950 A all fuel, six speed .so I know they made them . Mine has had the manifold replaced. All fuel manifolds have not been availible from deere for many years. My 51 gas A has a bigger fuel tank than the all fuel.
