1940 john deere h compression
mel calhoun
07-04-2000 15:32:11
hi, i have a 1940 john deere "H" , i had the engine rebuilt and the compression is 30 pounds in both cylinders when hot. is this right if not what is the compression to be.
thanks mel
Idaho Curt
07-06-2000 11:40:15
 Re: 1940 john deere h compression in reply to mel calhoun, 07-04-2000 15:32:11
You may want to check the cam timing if everything else checks out.
Curt
clooney
07-05-2000 18:24:00
Mel, the compression should be 80 psi, hot with the carb wide open. If it is 30 psi, even, and it starts I question the accuracy of your compression gage or you don't have the carb. open or you have a plugged intake system. The fact that it is even side to side says that whatever is causing the low compression is the same on both sides( highly unlikely) Maybe the piston rings haven't seated yet & they don't seal right until the engine fires (possible). An intake restriction such as a closed carb., plugged air filter or choke on will cause low readings also.
