JD 60
Jeff
07-27-2000 18:09:12
Can anyone tell me where I can find the serial # plate on a 60 JD.
Thank you!
Mike Aylward
07-28-2000 05:33:08
 Re: JD 60 in reply to Jeff, 07-27-2000 18:09:12
Jeff, they put the serial number plate in at least three different places on a 60, depending on it's age, but all are in the same general area. The very early ones had it in the same place as the older tractors, right under the distributor on top of the main case. Tractors a little later had it almost directly in front of the belt pulley on the main case. Later ones had it in a similar place, but mounted lower. Not trying to pick nits, but that's where they put them. Hope this helps. Mike
duke
07-27-2000 19:48:40
Look forward of and below the clutch pully
