'37 B manifold
Matt
08-18-2000 17:45:43
I have a '37 JD B (ser. 42598) I have had it for about 4 years, i was going to put new pipe from the manifold to the muffler on it because mine was welded up and bent. I got a new one from Deere and went to put it on but it the manifold part where it bolts on is Horz. and the pipe is vertical. I looked at some pictures and the manifold seems to be off a early styled B. My question is, would a pipe off a early styled B work? Or do i need to get a new manifold. About how much is a used one? I am only 17 and want it to look half way right. I just don't like that old pipe makes the tractor look like junk. Thanks
Todd
08-18-2000 21:20:04
 Re: '37 B manifold in reply to Matt, 08-18-2000 17:45:43
To use the correct pipe you will have to replace the manifold. The manifold you have is off of a early styled B which has more bend in the pipe to connect to the muffler, which is in the center of the hood (your B is side by side). Now you can take your old pipe, saw it off at the flange and go to a muffler shop and have a piece bent at a 90 degree angle, cut it off at the proper length and weld it in the correct position. You can make a decent looking pipe this way. It depends if you want to shell out the money to make it perfect. It's not always necessary like some people say.
