40 Motor Oil
Joe Badgett
08-27-2000 05:50:09
I just purchased a JD-40S. What type and weight of motor oil is recommended for this tractor. I know 10w or 20w was the original spec., but don't know where to find such. Would a 10w-30 or straight 30w be better?
bo
08-27-2000 17:04:47
 Re: 40 Motor Oil in reply to Joe Badgett, 08-27-2000 05:50:09
I've always used straight 30 in mine and it runs great.
Paul from Michigan
08-27-2000 16:28:39
I have an "H" that I have used for over 27 years. I overhauled it in 1974 and it's had nothing but Quaker State 10W40 oil in it since. It wasn't babied most of those years and was the only tractor I had for a while. In 1999 I restored it and checked the engine for wear. I found less than .0005 wear on the rod bearings, and no measurable wear on the crankshaft. The cylinder bores had less than .001 of taper in them. I think the multi-grade oils are OK based on my experience. Frequent oil changes and regular maintenance are equally important. Just my opinion, Paul
clooney
08-27-2000 06:18:11
Joe, it depends on how much wear is on the engine & what you want to use the tractor for. If all you are going to use it for is parades,play & light work use a good quality 10W30 or 10W40 or even a 15W40 oil. If you are going to work it hard (pulling on the governor at wide open throttle or plowing) then use a good quality 30W, or if much wear on engine 40W. A diesel rated oil will give you a little better protection under load but has more sulfur in it & tends to make more sulfuric acid so don't use it if the tractor is just used a little then sits a lot.
Joe Badgett
08-27-2000 06:26:09
 Re: Re: 40 Motor Oil in reply to clooney, 08-27-2000 06:18:11
Thanks for your input. I had just changed the oil and used 30w but was having second thoughts. I don't really know how much wear is on the engine but it seems to run pretty good. I will be doing some plowing and loading it pretty good, just not that often. I feel a little better about my choice now.
