Engine runs on on on...
2510 Guy
11-10-2003 20:43:03
Having trouble sutting down my 2510. When I turn the ingnition off, the engine continues to sputter for about a minute and emits clouds of black smoke, (you know what they say, it's hard to kill a Deere!) A friend told me to spray Marvel Mystery oil directly into the carb intake to clear out the carbon build-up. I tried this and it seemed to work for a few days, but the problem has returned. Any suggestions would be appreciated.
Tom
11-10-2003 23:03:54
 Re: Engine runs on on on... in reply to 2510 Guy, 11-10-2003 20:43:03
Guy,
When you turn off your ignition switch, it immediately stops generating sparks in your spark plugs. The engine still makes a few revolutions and still has fuel/air mixture being drawn into the engine through the intake valves. However, because you don't have a spark in the spark plug, the fuel/air mixture doesn't ignite and the engine just cruises to a halt.
With engine run-on (sometimes called dieseling), something inside the combustion chamber is so hot that it continues to ignite the fuel/air mixture in spite of the fact that the spark plugs are not sparking.
Some of the things that I've heard of that can cause the problem include:
1. built up carbon inside the combustion chamber as a result of having run the engine with bad spark plugs in the past
2. spark plugs that have accumulated carbon on them but have not yet fouled out
3. cheap, low octane gas that ignites at much lower temperatures that higher octane gas requires
4. timing advanced too far
So, having said all of that, I think I'd first install some new plugs, then run some top-end cleaner additive through a couple of tanks full of gas, try buying some mid-grade gasoline for a couple of tanks of gas, and check the timing.
Good luck. I'm sure that you'll get many more opinions of how to fix this problem.
Tom
david val
11-11-2003 02:17:24
 Re: Re: Engine runs on on on... in reply to Tom, 11-10-2003 23:03:54
there is also a solenoid valve that acc. to a 2020 carburetor cutaway in the service manual (i guess 2510 is basically the same) that shuts of fuel flow to carb nozzles in order to prevent the dieseling. checck its operation.
david
Glen in TX
11-11-2003 15:15:01
 Re: Re: Re: Engine runs on on on... in reply to david val, 11-11-2003 02:17:24
Yep, thats what I was thinking too, some of the 180 and 202 engines had carbs with the solenoid shutoff nozzle. Seems like we cleaned carb, put a kit and solenoid on to cure that problem once on 180 engine in 880 swather once had.
