HELP John Deere 1020 manual steering
John D
09-12-2000 03:01:29
I am working on a 1967 jd 1020.I replaced the steering wheel and noticed that water got into the top two bearing.I cleaned regreased and reasumbled.I noticed that at the bottom the the steering shaft has some left to right play in it.So I readjusted the top locknut and adjuster. this seams to make it harder to steer and their is still left to right play in the shaft. Also I flushed out the oil res. and replaced it with hydragard oil. please help if you can. thanks John D
david val
09-12-2000 20:56:37
 Re: HELP John Deere 1020 manual steering in reply to John D, 09-12-2000 03:01:29
if by 'steering shaft' you mean the shaft that the steering arm is attached to at the left side,then a little (up to 1/16 in.) play is no problem at all. the bearing at the top is spherical and no matter how tight it is, it will not eliminate play at the opposit side. adjust bearing so that there is just no play in the bearing.
david
