Carb settings on B
jerry holzerman
09-12-2000 13:55:41
I just bought a 1937 B.IT has a new carb. still on factory settings.I got it to run by pulling it with our 50, but it won't stay running.I'm pretty sure the carb is not set right so can someone tell me a good place to start with the screws(1 turn out or 2 turns out or what?)Thanks for any help.
Mike Aylward
09-12-2000 14:18:19
 Re: carb settings on B in reply to jerry holzerman, 09-12-2000 13:55:41
Jerry, the idle needle should be set about 1 1/4- 1 1/2 turns open, and the load needle about 3/4- 1 turn open. Your carburetor may vary slightly from this, but if it varies very much it needs cleaning, regardless of whether or not it says "rebuilt". Hope this helps. Mike
G Taylor
09-12-2000 14:15:07
Tune up specs and other vital service info from this site or cheap and direct from Deere at 1-800-522-7448.
