You will have a problem eather way. We have 1700# bales from a JD 510 round baler. When we have the bale fork on the 3 PT of the backup 730D WITH 5 factory front end weights AND a factory sq axel wide front which adds about 1300# of weigth on the front end over a standard roll-a-matic and off the level going up hill will put the front end right in the air. From the hay yard up the driveway to the cow yard we have to back up the drive. In the field we come in to the bale from the down hill side a back up to the field road, then we can drive down the hill 1/2 mile to the hay yard. We have a "BEEFED UP" (Also read that as "HIGHLY MODIFIED"" JD 35 loader on a 630. The weight of the loader on the front and a factory sq axel wide front will act as a counter weight on the front so the 630 can take a 1700# round bale anywhere on the 3 PT. We have a grapple fork on the bucket of the 35 loader and even with a 1000# JD 115 rear blade on the 3PT PLUS 8 wheel weighs (1200#) AND the tires full of fluid, when we have a 1700# round bale in the grapple, we are spinning the rear tires going up even a small hill. 1st gear NEVER higer then 2nd gear with a bale in the grapple!!!!! And then there are still times I worry that the front end can take it over ruff frozen ground or in the spring mud when you turn the streeing wheel, hit the one brake and STILL go straight. The 35 loader was built for the 40 420 430 1010 2010 and the 3010,,,,BUT the frames were differant. The boom, buckets were the same,,,but the cylinders and the frame s were differant depending on what tractor it went on. The frames were a three piece frame that bolted together. A 35 loader frame for a 430 will not fit a 2010 without modifacation. The 36A replaced the 35 and had a differant frame that used the same pieces no matter what tractor it went on, it just bolted together on differant holes depending on what tractor it went on. SPECS from the ops manual 35 Loader as mounted on a 430 weight of loader 775# rated brakaway cap 1,652# Rated lift to full height 1,348# lift height 9 feet 9 inchs 36A Loader as mounted on a 2010 utility weight of loader 1,016# rated brakeaway cap 2,500# rated lift to full height 1,600# lift height 9 feet 7 inchs. Go to the photo gallery and under surch deleat DEERE and type in my name and a pix of the 630 and the 35 loader should come up, (If it's working. It works about half the time. Or you can e-maile me at hanleyranch@yahoo.com and I can send you some pixs of how we handle round bales. PS; The 35 loader came with 2 1/2 inch dia lift cylinders. We replaced them with 3 " and then replaced the 3" with 4". And have 3" cylinders on the bucket tilt. The cylinder to run the grapple is 3" You say you only have single remotes. The 2010 had a way to tap into under the dash so you can have remotes onj the loader so you can have a hyd bucket. It shows how in the ops manuel for the 36A mounted on 2010. Would I move any round bale over 1000# with a 2010? NO.
