2010 Power Steering
Prune Picker
09-24-2000 09:24:25
I have located a 2010 utility gas tractor in decent shape for $3500. It runs well but the power steering continues to turn the steering wheel after the operator stops turning. I am new to this model range..... any comments from you new generation fans out there?Are the 2010's worth restoring and working? Is the PS a problem on these models?
Brian Furey
03-30-2003 11:02:35
 Re: 2010 Power Steering in reply to Prune Picker, 09-24-2000 09:24:25
the bearing lock nut on the spool valve is probable to loose. It should be between 20 and 30lbs.
