JD 430(59 model)
jeff
09-24-2000 11:56:43
is there anyone out there that can help me .I have an old JD 430 that I use , I would like to put a front end loader on it for light work around the farm. but unable to find the hardware to mount the loader to . Does anybody know of a kit or of a dfferent model that I can modifiy to make it work on my tractor. I thank you for your time and help.
Bguy
10-21-2003 08:37:53
 Re: Model B clutch lever removal in reply to Steve M., 10-21-2003 08:19:14
Steve, These things can be a real problem. Don't hit on it too much or you will break the ear off of the first reduction cover. I have been lucky in that I have been able to get all of mine out heating it with a torch while tapping on it. Sometimes I will put some penetrating oil on it for a few days first. Be patient, keep heating and tapping and it should eventually move. There was a guy that used to have an ad in some of the magazines advertising a puller but I have never seen one.
Charlie
09-25-2000 09:41:02
 Re: JD 430(59 model) in reply to jeff, 09-24-2000 11:56:43
Jeff, I don't know if this helps but I have a JD 440 Industrial with a JD model 71 loader. It's not a huge payload but very handy. There doesn't seem to be a huge diference between the 430 and 440 so the 71 may bolt up fine. If you have specific questions let me know.
Charlie
