820 pony motor
Jeff
10-12-2000 09:27:48
I do not get any spark when I crank the pony motor am I right to assume the coils are bad?
Jeff
craig m
10-12-2000 11:10:11
 Re: 820 pony motor in reply to Jeff, 10-12-2000 09:27:48
If you need new coils you can get them from Bill Lopoulos magneto parts at (www.magnetoparts.com)for about 1/2 what you can at John Deer. I got some for my 720. I got new points coils and wires they work great.
G Taylor basics
10-12-2000 13:48:40
 Re: Re: 820 pony motor in reply to craig m, 10-12-2000 11:10:11
Before replacing coils check for six volts while cranking the pony and three volts to the coils while running . Check the points are making & breaking the circuit and not stuck "up".
Charles
10-12-2000 16:45:54
 Re: Re: Re: 820 pony motor in reply to G Taylor basics, 10-12-2000 13:48:40
I second that...there is (at least on my 70D) a connection from the pony ballast resistor (on the back of the ignition switch) at the starter switch, which applies the full battery voltage to the coils while cranking the pony.
Also, I got pony coils at Central Tractor for $84.99 a pair. Many other places advertise them in 2-Cylinder and others, usually 100-125 a pair.
Didn't even try at the dealer :)
