Do you paint the exhaust manifold? Hmmmm..
jim Nielsen
10-18-2000 00:28:31
Hi, Im doing a 'restoration'of a JD 2010D. Iv'e just started painting the major engine components - still dissassembled. What I want to know is this: The exhaust manifold is a yukky rust color, is it traditional to paint them black (with high temp paint) in a full restore, or to leave em 'rust' colored?
Any advice appreciated, Thanks, Jim from Australia.
clooney
10-18-2000 15:37:09
 Re: Do you paint the exhaust manifold? Hmmmm.. in reply to jim Nielsen, 10-18-2000 00:28:31
Jim, unless you get ALL the rust out of the casting pores or kill the rust that is in the pores it won't make any difference after a good hard hot run & a damp night. If you want it to stay black without repainting it continually you should send it out to be porcelainized (sp?) I have seen a couple of tractor manifolds done that way & they look fantastic & hold up real well. Show car people have been doing that for years.
John T
10-18-2000 11:39:13
Jim, A Perfectionist Correct Policeman might say (On the older ones) they were painted green at factory then rust if you wanna be absolutely original, but I say heck with them. We paint ours flat black with the Eastman High Temp paint and we like it and if others dont they can kiss our grits. I plan to use a few more more stainless steel unpainted bolts when I re paint my B, and even if not original, I think it looks neat as heck. One mans opinion. John T
MikeH-Tx
10-18-2000 12:19:21
 Re: Re: Do you paint the exhaust manifold? Hmmmm.. in reply to John T, 10-18-2000 11:39:13
John, I agree with your attitude!
Eastman Hi Temp gray is what I used after wirebrushing and it didn't last worth a hoot. Maybe I didn't get the manifold clean enough.
We'll see if the fancy chemical rust converter helps. I'll get back to you in a year or two.
John T
10-19-2000 06:33:42
 Re: Re: Re: Do you paint the exhaust manifold? Hmmmm.. in reply to MikeH-Tx, 10-18-2000 12:19:21
Our painter Paul used Eastman high temp black and it seems like its gonna last a good while. However, he used some Eastman aluminum color which burned right off??? John T
MikeH-Tx
10-18-2000 08:12:41
This won't answer the "what is the tradition" question, but a related comment: Just painting the manifold won't work. I tried using Rust Converter from Rustoleum, after wirebrushing, then used hi temp paint, and like what I see so far. (Hi temp gray on my JD-H). Trouble is, you don't know how well you did for a year or so. I have seen when I just wirebrushed followed by hi temp paint, it didn't last six months before I had a rusty manifold again.
