1947 M
Reasonable offer?
Steve Sayers
10-23-2000 06:48:31
I just looked at a late 1947 M. Serial number 13147. It needs the following to restore: New seat, battery, starter ring
gear, starter drive gear, steering wheel, complete air cleaner assembly, muffler, lights, sheet metal is there, but bent almost
beyond repair (maybe beyound repair). The radiator holds water, but it has been damaged and probably needs to be
replaced. It needs an ignition switch, and sheet metal around the battery box. Tires are OK, very little rust, but needs
paint. It was operated for many years without an air filter, so engine could have extensive wear. I figure it needs between
$1500 and $2000 in parts alone. Asking price is $1500 and I am in Alabama. I offered $700. Question to this
distinguished board is what would be a fair price??? Am I low-balling or is my offer about right?? Oh yea...can I even get
all the parts I know I need???? Thanks for your help...Steve
JCS in Pitts, PA
10-23-2000 09:58:32
 Re: 1947 M - Reasonable offer? in reply to Steve Sayers, 10-23-2000 06:48:31
I will sell you one!
JD 48B
10-23-2000 09:39:54
I wouldn't give anything over $500 if that but that is just my opinion. I think you might be running into more bad than good. You should be able to get the parts you need from the net and your local sources.
GENE
10-23-2000 19:08:53
 Re: Re: 1947 M - Reasonable offer? in reply to JD 48B, 10-23-2000 09:39:54
I PAYED $250 FOR A MT IN ABOUT THE SAME SHAPE A COUPLE YEARS AGO, HANGE ON WHEN YOU GO TO BUY YOUR IGNITION SWITCH AND YOU CAN FIND ABOUT ANY PART YOU NEED $$$$$ BY THE WAY AT THIS POINT I PAYED TO MUCH FOR THIS ONE?????
