1936 AO Lube System
Darol
11-15-2000 11:45:50
How does the valve train get lubed on this tractor? Is it a gravity flow system fed by splashed oil coming off the governor drive gear or is there a special slinger in there similar to a small engine? Or is there some kind of pressure line/gallery that feeds oil into the gravity flow tube? The top end appears to be not getting enough oil?
Spokerd1
11-15-2000 14:35:52
 Re: 1936 AO Lube System in reply to Darol, 11-15-2000 11:45:50
Darol, The AO valve train gets its oil from the oil which is carried up the the gears and droped off in a cup inside the govenor housing. This then goes down the external tube to the valve cover. Then it goes thru a small oil tube in the valve cover which drips oil onto the valves and springs. It is not a pressure fed system.
Darol
11-15-2000 14:43:15
 Re: Re: 1936 AO Lube System in reply to Spokerd1, 11-15-2000 14:35:52
That was my question. The gears do carry the oil up to that little cup inside the housing...there is no "slinger". Thank you very much.
