1948B WRENCHES
REBECCA GOETZ
12-10-2000 05:51:31
MY FATHER HAS A 1948 "B" TRACTOR, BUT WHEN HE BOUGHT IT HE FOUND OUT HE NEED SPECIAL WRENCHES TO WORK ON IT. HE ASK ME TO SEE IF I CAN FIND ANYONE WHO WOULD SELL OR KNOW WHERE IT BUY.
tractorboy
12-11-2000 08:38:47
 Re: 1948B WRENCHES in reply to REBECCA GOETZ, 12-10-2000 05:51:31
Those are clutch head screws and were not supposed to be on a 48 model B. They are supposed to be Philliips screws on the hood and grilles . He can get a clutch head driver from Deere.
Stan
12-11-2000 13:58:54
 Re: Re: 1948B WRENCHES in reply to tractorboy, 12-11-2000 08:38:47
Tractorboy,
When did the clutch head screws first appear? I have heard that there were two different sizes of the heads, but I don't know for sure.
I have a clutch head screwdriver that came with our '49 A (built 5/31/49), but don't know which size it is if there is a difference.
Stan
burnsOmatic
12-11-2000 16:30:10
 Re: Re: Re: 1948B WRENCHES in reply to Stan, 12-11-2000 13:58:54
I am not sure when the first clutch head bolt appeared but I am fairly sure that they are all the same size (clutch insert). These clutch head bolts are as confusing as decals size/placement. A 48B takes the round head with a philips center while a 48 A takes the machine bolt with the clutch center. My 49 G takes a round head with a clutch head center. There is a gentleman who sells bolt kits for your type of tractor located in W. PA. If you need his number reply to this posting. Snap-On provides two different size clutch head bolts.
Shorty Dear
12-10-2000 19:41:44
Rebecca,
I would imagine he wants a flywheel wrench. John Deere made a special flywheel wrench to tighten the flywheel onto the crankshaft. The same wrench that fits the B will also fit the model H. I have these wrenches for sale if he wants one.
MN Bob
12-10-2000 13:06:47
Rebecca; Not sure if he has heard of some wrench that was sold with the B at some time or what. You may want to explore www.shaysnet.com They have lots of info on B's and its also entertaining and informative. Bob
tractorboy
12-10-2000 08:42:04
I got some B's too and the only places that give a prob is the Flywheel. I fixed me up a special wrench to tighten it so now I dont have that prob anymore . A good set of 1/2 and 3/4 drive sockets and wrenches should take it all the way down . You will need a good torque wrench capable of pulling 150 ft lbs and that should do it . Thats my 2 cents worth
gary
12-10-2000 06:06:32
Rebecca,
I have '48 "B" myself, and I haven't found any basic maintenance that couldn't be done with conventional wrenches, in fact a lot can be done with a 12" adjustable wrench. If he were planning on doing a major engine overhaul I would imagine he would need some specialty tools, but for routine stuff a decent set of sockets and combination wrenches should be more than adequate.
Maybe you could re-post and be more specific about what tasks he thinks the special wrenches are needed for?
Clyde Scott
12-10-2000 06:01:18
Rebecca:
What are the "special wrenches" your father needs to work on his '48 B..?? I have worked on several of these old tractors with off the shelf wrenches without any special ones.. Maybe he could explain a bit better what he needs and we could then help.
Clyde Scott - Moultrie, GA.
e haydal
12-10-2000 20:49:03
 Re: Re: 1948B WRENCHES in reply to Clyde Scott, 12-10-2000 06:01:18
I wonder if Rebeccas, father is talking about those screws that hold the grill and flywheel cover on also used in other places.you know the ones with the funny heads.I got two 48 b and they are on both of them
