I assume from your description that you have a late model B. You mention that you had the cover off of the transmission. For that reason I suspect your had the transmission in the low range but the gearshift in the high range when you replaced the cover. For that reason I'd do the following. Remove the cover. Inspect all of the detents, the shifter shafts (not bent), the forks (none broken or cracked) and make sure that the shifter gates can all be lined up. You'll see 4 shifting forks. The 'odd one" (looks very different from the other three) is the hi/lo range shifter. It has a single "high level" gate while all others are double gate shifters with their gates at a lower level or "deeper in the transmission". The forward most of the lower three is the 1/3 Reverse shifter. This is the only shifter that has three detents. Make sure it is in neutral which is the center position. The next back would be the 2/5 shifter and the rear most shifter is the 4/6 shifter. Push these last two shifters to the left detent. All of the gates of the lower three shifters should now line up and your belt pulley should turn freely because the transmission should now be in neutral. If they don't line up smoothly, then the positions of the shifter shafts would need to be adjusted. That would best be another post and we'll assume they line up for now. To reassemble, I find it easiest if I first place a late model B in 4th gear. To do so, slide the range shifter (the odd one) to it's left position which is the low range. Slide the rear most shifter (4/6) to the right or "in gear" position. The other 2 shifters MUST remain in their neutral positions. Place the gearshift (the handle proper) in the 4th gear slot of the shifter quadrant and block it there with a block of wood. When a late B is in 4th gear the gear shift is very nearly perfectly vertical. With everything set in this manner, the entire quadrant assembly, cover, steering pedestal and gearshift can be lowered straight down positioning the lower ball of the gearshift in the 4th gear (left) gate of the 4/6 shifter. Loosley install the cap screws and "run the shift pattern". Remember you may have to turn the pulley occasionally to get gears to line up. If it shifts properly into each gate, tighten the cap screws. If it does not shift properly, then the shifter shaft positions may need to be adjusted but try all this first. Let us know what you find. Later!
