410b hydraulic filter
John Trinder
11-15-2003 14:21:46
I just recently bought a 410b and performed it's first 300 hour service. Everythihg went great except for the hydraulic fitler. I don't have the correct size wrench to take the can down and no one can seem to tell me what the correct size is. The reverser and the hydraulic can both take the same size but I used a big adjustable for the reverser and you can't get at the hydraulic can with it because of it's location. So i need to buy the wrench for the hydraulic filter but I need to knwo what size it is. If anyone can help me out on this it would greatly appreciated. Thanks
Jonathan
11-16-2003 05:10:56
 Re: 410b hydraulic filter in reply to John Trinder, 11-15-2003 14:21:46
I forget what the metric measurement of that "nut" on the end of the canister is...but an 1-5/8" wrench always worked for me...It will fit a little loose, but it does work...and usually more readily available than the metric equivalent..take that little plug out first to drain the canister....should also be the same size on the reverser filter.
david val
11-15-2003 23:35:53
all john deere's with this type of filter had the same head size-3/4". however, head may have been rounded or welded upon and an adjustible/pipe wrebch may become nessessary.
david
