JD Model 70 Exhaust Pipe
Jim
01-08-2001 09:27:07
I purchased a 1954 JD 70 recently and it has a straight pipe for an exhaust. It's so loud my wife won't let me run it when she's around. Since I'd like to keep her a while longer(my wife that is) can I purchase a muffler for the tractor and can you suggest a source. Thanks
Karl Bader
01-08-2001 17:10:08
 Re: JD Model 70 Exhaust Pipe in reply to Jim, 01-08-2001 09:27:07
try www.oldjd4u.com if you don't see it on their online stor e-mail them, they probably have it.
Hope this helps!
Karl
luckydog
01-08-2001 13:03:09
Jim-- If you want to quiet it down (your wife) buy a round muffler. If you want to make her smile (your wife he-hee) put an oval muffler on it. The oval muffler is much easier on the ears plus you can talk while it's running. Just a thought. luckydog
DON
01-08-2001 12:21:18
JOHN DEERE MUFFLERS ARE THE ONLY ONE'S THAT SOUND RIGHT . SURE THE OTHERS ARE CHEAPER BUT THEY SOUND THAT WAY TOO.
G Taylor
01-08-2001 11:51:47
The oval muffler from the 730 should retrofit. If shed doorway clearance allows a length of pipe after the muffler assists quieting even more.
Kris
01-08-2001 10:04:02
Also try Tractor Supply Co. if you have one near by. I get a lot of parts there.
Deere-hunter
01-08-2001 10:00:07
Your'e local J.D. dealer should be able to get you one. If you have a central tractor store near you try there first its probably far cheaper there. Also theres a store called fleet-farm that probably has them for a fair price.
Gary-B
01-09-2001 19:10:02
 Re: Re: JD Model 70 Exhaust Pipe in reply to Deere-hunter, 01-08-2001 10:00:07
Luckydog hit exactly on the head. Couldn't say it better myself. I have 1954 70 gas. perfect hay ride tractor.
Gary from Iowa
