1962 JD 1010 gas
buster
01-09-2001 21:16:20
What are the price ranges of this tractor? What HP is it. Can it be used for a small alfalfa hay feild? aprox 160 acres small bales. Are parts available? I found one for $1,000 with a plow. needs a battery and a carb rebuild. Is that a good price?
Sam
01-10-2001 18:43:01
 Re: 1962 JD 1010 gas in reply to buster, 01-09-2001 21:16:20
You don't state the model - RS,U,T,RC etc. Sounds to cheap. I sold a parts tractor (RS) with engine apart for $1000. Check oil for water (antifreeze). If you have engine problems this is the first place it will show. Just open the drain on the crankcase and if you see water stay away. The better 1010s were the later ones with the spin-on oil filters. There are a lot of better tractors out there that can be operated and maintained less expensively.
hunter
01-10-2001 16:49:30
36Hp. yep great price. some folks talk junk about them but I own and work 1 and has ALWAYS gave excellent service. It should do the 100+ acre thing but that seems kinda big though. I'd give it try anyway. The only problem with that much acreage is that it'll take awhile.
rhudson
01-10-2001 17:39:02
 Re: Re: 1962 JD 1010 gas in reply to hunter, 01-10-2001 16:49:30
same story here, i never knew the 1010's had problems until reading this post. we've had ours since 1963. some carb problems, (dirty gas), one engine rebuild, replaced brakes, clutch and muffler that's about it. it does seem to be a gas hog though. around here they bring about $3000 to 3800. check it over good because that seems too cheap.
Richard
01-10-2001 18:54:04
 Re: Re: Re: 1962 JD 1010 gas in reply to rhudson, 01-10-2001 17:39:02
I have a 1010 diesel and it is 40hp. No major problems. When I bought it I gave $3500 for it and 6ft mower (bushog type). I had a friend who had a gas model and other than dirty carb and water in gas, I am not aware of other problems with it.
