Propeller shaft for JD L
Joe Greene
01-15-2001 14:59:36
I have a JD L s.n. 626955 that needs a propeller shaft. I have a shaft from an LA that is 23" long outside of flange to outside of flange that won't fit because it is slightly too long. Does anyone know exactly how long the shaft for the L should be? My tractor has no pto or belt pulley if that matters. Thanks.
John K
01-15-2001 19:30:29
 Re: propeller shaft for JD L in reply to Joe Greene, 01-15-2001 14:59:36
Joe,
I just took a careful measurement of the prop shaft from my L, s/n 632289. It is 22 13/16" overall length BUT - there was a change in the part number at serial number 629000. According to the JD parts catalog, your tractor should have part no. AL2210T. Mine is part no. AL2614T. There are no dimensions given in the parts catalog, so I don't know what's different. The reason for the change seems to be that this was also the serial number break when JD changed from a top-shift to a side-shift transmission. Sorry I couldn't really answer your question.
