1939 B steering gear lubricant.
Cam
01-22-2001 11:06:18
Just yanked out a bad steering worm front bearing and race. The old lube was very suspect and unidentifiable. What is the correct replacement lube? Thanks guys.
Mike Aylward
01-22-2001 16:43:16
 Re: 1939 B steering gear lubricant. in reply to Cam, 01-22-2001 11:06:18
Cam, the original lubricant was transmission oil, but I prefer to use John Deere Corn Head Lubricant in these tractors. It will "stay put" much better than gear lube will, and will lubricate as good or better. One tube or a part of one will probably be enough. Hope this helps. Mike
Cam
01-22-2001 19:36:49
 Re: Re: 1939 B steering gear lubricant. in reply to Mike Aylward, 01-22-2001 16:43:16
Thanks a million.
