JD 40 Oil FIlter Sealing Plate
Joe Badgett
02-03-2001 13:05:32
I need to find a lower oil filter sealing plate for a John Deere 40. Anyone know where I can get one? Is ti OK to run tractor without this plate...what damage could it cause?
lc
02-03-2001 18:21:23
 Re: JD 40 Oil FIlter Sealing Plate in reply to Joe Badgett, 02-03-2001 13:05:32
You can get the part from Jerry's Reproductions-2313 CO RD 481- Evergreen, CO 80439. Can't come up with the phone # though. Can't say that i could tell any difference in the oil pressure . Book says its supposed to be there .
Dan
02-03-2001 18:20:59
had the same problem with my 430. Think it often gets tossed out with the filter. since you dan't orderit from JD, they came up with a large flat washier with the right sized hole in the middle. Without the washer I don't think oil will circulate through the filter properly or may bypass. If you go to a place that hs a variety of hardware you should be able to find the big flats, got mine from the JD dealer
