1945 B clutch
Stevie
02-07-2001 18:02:34
Hello. I have a 1945 "B' and My Dad told me that he thinks it needs a new pulley. He has had trouble adjusting the clutch. He told me something about toggles? Are these separate pieces or are they attached to the belt pulley. Any help will be greatly appreciated in this matter. THANKS in ADVANCE.
Sincerly
Stevie
Paul from Michigan
02-07-2001 19:42:03
 Re: 1945 B clutch in reply to Stevie, 02-07-2001 18:02:34
There are two parts in the clutch assembly that frequently get overlooked and can make it almost impossible to get a good adjustment. The toggles are sort of dogbone shaped parts that transfer the horizontal movement of the operating sleeve to the clutch dogs. There are three of them and if the spherical endss get worn they will be too short to work well. Also if the dogs, which transfer the motion from the toggles to the operating bolts, which in turn pull the discs together to engage the clutch are excessively worn they will prevent good clutch adjustment. There are also three of these. You should check them for wear and replace if needed. That will probably fix your problem. Good luck, Paul
