1955 John Deere 70
Alan Baldwin
02-16-2001 06:38:14
Where do you check the fluid levels on the 70 such as the oil, Hyd. And rear end Im not sure and my IT manual tells how much but does not show where to check the levels Any help would be greatly appreicated. Thanks Alan
G Taylor
02-16-2001 18:48:06
 Re: 1955 John Deere 70 in reply to Alan Baldwin, 02-16-2001 06:38:14
May want to see "todays tractors" area for thoughts on I&T manuals.
Alan Baldwin
02-16-2001 14:20:32
Thanks lucky dog that will get me going for awhile.
luckydog
02-16-2001 13:23:01
Alan--On your oil look in front and below the clutch pully,below where you adjust the oil presure ther will be a plug setting in a outset cap-loosen about 1/2 way and the oil should drip out. If it does not add until it does. Hydro-Page 67 in the I&T man. figJD1210 where hoses come out of the power trol, to the right of the hoses there will be a drain-cock sticking out of the side, loosen and pour fluid in til it runs out of the drain-cock. ON your PTO there will be a plug, I&T man. page 61 figJD1190. Loosen, take out and fill. Power steering, there is a cap that you have to remove that is in front of the radiator cap. Should be a dipstick down in that hole. Hope this helps. luckydog
luckydog
02-16-2001 13:36:49
 Re: Re: 1955 John Deere 70 in reply to luckydog, 02-16-2001 13:23:01
About forgot,your rearend fluid is checked by I&T man Page 71 figJD1225 below the rockshaft is a big plug that takes about a 1in.wrench to loosen. Fill till full. luckydog
