1948 B head question?
Bill Oakes
02-17-2001 14:18:46
I'm new to John Deere 2 cylinders and have a question. Every manual I have seen says that there are removable pushrod seals in the head. I only have rough casting holes through the head where the push rods go. I am confused; can anyone help me understand? Thanks in advance, Bill
John T
02-17-2001 21:27:58
 Re: 1948 B head question? in reply to Bill Oakes, 02-17-2001 14:18:46
Bill, they are also called pushrod tubes and I have seen them both steel and brass. If they are corroded bad, they can allow water to leak into the head area. On the unstyled B's if you drill out the manifold stud pilot holes too deep, you can drill into and ruin the tubes. They are a pressed in fit and to remove and reinstall them use an exact proper sized bushing driver. Place the new ones in a freezer for an hour or better before driving them in. We had 2 or 3 in a row that leaked there and needed new pushrod tubes. Ol John T
clooney
02-17-2001 15:07:08
third party image
Bill, they are in there you will have to look real hard as they are pressed in & expanded to fit tight & not leak. see # 9 on the picture.
