1020
john
03-18-2001 08:41:33
whats a 1020 worth? has been sitting for 7 years. pto doesnot work hasnt for several years only has 3pt no other hyds. could you get remotes for it as an option? has 1400 original hours on it tires are dry rotted bad. a pig farmer owned it.
john
03-18-2001 16:51:51
 Re: 1020 in reply to john, 03-18-2001 08:41:33
thanks bob it is a gas it sounded like it would load up or try flooding its self out at an idel.
it had 13-6-28's and 6.00-16's on the front. it5 ran real good other then that
Bob W
03-18-2001 09:31:20
John- you didn't say if this tractor was a gas or diesel model. To give you an idea a year ago I bought a 1967 1020 gas with 48 loader 14.9 x26 rears 7.60x15 fronts,and 3 pt for$5500 (CAN) Its a good running tractor and is used almost daily for feeding chores around here. Yes you can put remote hydraulics on it,check with a dealer or wrecker-I put a set on mine that came off an1830 (Canadian model) but any utility tractor version would work OK
