3020 fuel guage problems
John S
03-29-2001 20:39:34
I got some great help last month in determining if my fuel guage or sending unit were bad. I have now replaced the sending unit, but guage reads full at all times--the same as when it is directly grounded. I tried both sending units that Deere makes for this tractor with the same results. Could I also have a bad guage or some other problem?
twopop
03-31-2001 13:48:27
 Re: 3020 fuel guage problems in reply to John S, 03-29-2001 20:39:34
with the key on and the sending unit wire disconnected,you should have 12volt power to one of the guage terminals and a slight amount of power on the other terminal.if power is not going thru the guage then it is no good.if this is a diesel it has to be negative grounded power
John
03-31-2001 18:39:19
 Re: Re: 3020 fuel guage problems in reply to twopop, 03-31-2001 13:48:27
Thanks for the help--I'll check it out.
