2010 No power Steering
Gary
04-02-2001 21:02:35
Had power steering when put away for winter,When took out of storage, No Power Steering, Thinking it was steering motor up frt. of Tractor I disaassembled all Looks good. Must be at steering wheel or pressure problem. Can anyone help. Thank you.
JD Mech
04-06-2001 21:33:56
 Re: 2010 No power Steering in reply to Gary, 04-02-2001 21:02:35
Does any other hydraulic functions work like the brakes, rochshaft, remote outlets? If they don't then after changing filter if there still are no hydraulics the front pump might need destroked. You can get a destroking valve from your dealer. Your dealer can also show you where to screw it on the pump and what to do. What this does is put the front pump in neutral and burp the system.
Bryan
04-03-2001 14:28:34
Have you changed the hydraulic filters, theres a good chance after sitting so long, it will also be the cheapest place to start. hope this helps.....Bryan
