3010 help
jerry k
04-06-2001 04:46:58
looking at a 3010 jd any info would be helpful dont know anything about them . it is a gas modle .h any big problems with them????? please help thanks jerry...
Larry D.
04-06-2001 07:11:11
 Re: 3010 help in reply to jerry k, 04-06-2001 04:46:58
The 3010 gas is a good tractor if in good shape.
We have had two over the years both good ones.
With exellent power steering and power brakes they
are a pleasure to operate. They are not the most econolical on gas but at approx. 55 HP it will do a lot of jobs well for you. The hydrolic system
is a closed center type running at a little over
2000 psi. The 3pt hitch makes it even more useful. We pulled 3 plows in heavy clay with good results.
If possible take someone along who has expeience
with this model. Being a new generation tractor they tend to be a little more complicated to work
on but rutine maintainance is easy. If you get the
tractor be sure to get the manuals they will aquaint you with both operation and service.
Good luck with your hunt.
Larry D.
