1941 H
Johnny Head
04-06-2001 12:12:00
I have a 1941 H John Deere Tractor Serial No. 40065. It was really a project since it had been setting outside for 15+ years. Suprisingly I got it running without too much trouble. The transmission stuck two days after I got it running. When I took it apart I found that the 2 needle bearings part no. JD7915R need replacing (they fit on the countershaft part no. H148R). My JD Dealer says they are a discontinued item. I haven't been to local bearing supply company yet. Does anyone know of a good source and how expensive are they? I know needle bearings
are expensive.
clooney
04-06-2001 13:07:46
 Re: 1941 H in reply to Johnny Head, 04-06-2001 12:12:00
Johnny, if the bearings are bad there is a good chance the shaft is pitted & the bore of the counter shaft is rough or pitted (look them over real good). Charles Lindstrom probably has the parts to get you going again.
