1940B JD generator
Kbaker
04-11-2001 15:51:00
I have a 1940 B [slant dash], with starting and lighting. I would like to know just how the adjusting strap is supposed to mount. Mine is mounted to the fan support. But I can't help but wonder what the hole in the generator mount is for. Thank you, KB
ia dean
04-12-2001 17:36:04
 Re: 1940B JD generator in reply to Kbaker, 04-11-2001 15:51:00
Have a 40 slant dash with same mounts you described. The top mount to the fan shaft bearing housing is correct. My best guess as for the little arm on the bottom cradle is for some type of a belt or pully guard. I'll look for a parts manual for that model. We have unstyle and later styled B's but they don't have that mount
Kbaker
04-12-2001 17:53:32
 Re: Re: 1940B JD generator in reply to ia dean, 04-12-2001 17:36:04
Thank you for the information. I have a parts manual, but it doesn't show any pulley gaurd or anything else that mounts there as far as I can see. KB
