1020 hydraulic noise
James
04-12-2001 19:17:09
I have a '72 1020 with a very loud (I had the muffler off for a while, and could hear the noise over the exhaust) dieseling kind of noise that appears to be related to the hydraulic system. The noise is loudest near the shifter levers as opposed to up front where the pump is at. The noise completely stops if I use any of the hydraulics (loader or rock shaft). I don't have power steering, and the hydraulics all seem to work great aside from the overbearing noise. The noise is not effected by the clutch.
Thanks for any comments.
Joe-SE AZ Rancher
05-15-2006 10:52:14
 Re: 148 loader on 4020 in reply to JDBert, 05-15-2006 08:15:09
Thank you.... too heavy for the 14k trailer then. That trailer weighs 3200# by itself. Thank you for the information. Joe
Sam
04-12-2001 21:32:30
 Re: 1020 hydraulic noise in reply to James, 04-12-2001 19:17:09
David is on right track check brackets that hold the hydraulic lines to right side of engine make sure no metal to metal contact. Had same problem with a 2030.
davidval
04-12-2001 21:04:56
the main pressure line pases under the right footstep.sometimes tthe steel tube touches the footstep (above the brake valve) and transfers the vibration noise to the whole tractor.
david
