JD 420T Water Pump Lubricant?
jm
06-23-2001 02:39:04
I have a JD 420T and am in the process of overhauling the water pump. The I&T service manual states that to reinstall the pump you should hold the gasket and shim washer in place with Lubriplate. I went to the Lubriplate website and they only have about ten million different grades so I have no idea which one to get. Could anyone tell me the grade to use or an equivalent of something else. Also, do I use this lubricant on the main gasket that is between the water pump housing and the cover plate? Thanks.
