Where is the serial # located on a JD 50?
2N Ford MN
06-23-2001 07:25:42
Going to go try to get my brother's JD 50 started for the first time in several years.
While I'm monkeying with it I'd like to find the # so I can date it and buy parts if needed.
Thanks for anyones help.
DP
06-23-2001 07:48:14
 Re: Where is the serial # located on a JD 50? in reply to 2N Ford MN, 06-23-2001 07:25:42
Should be on the right hand side, to the front and down from the pulley. A few of the early ones were just below the distribtor.
ron
06-24-2001 19:15:28
 Re: Re: Where is the serial # located on a JD 50? in reply to DP, 06-23-2001 07:48:14
Mine is a 1955 and it has the plate on the right hand vertical surface of the engine crankcase just ahead of the pulley and I believe that most of them had it there.
2N Ford MN
06-23-2001 08:05:41
Thank you
