2010 Gas stuck engine
Mike P
07-02-2001 18:33:15
My father-in law gave me a 2010 JD. The last time it was run was 20yrs ago and at that time it was running well (per my wife and father-in-law), but of couse the engine is now stuck. Any advice would be apreciated. He did stick a can over the muffler. Thanks mike
Roxane
07-03-2001 09:08:30
 Re: 2010 Gas stuck engine in reply to Mike P, 07-02-2001 18:33:15
I have learned from a very old man that household ammonia works to unstick an engine better than anything, it's wierd but works...
ferrell freeman
07-03-2001 08:20:29
I,would remove the spark plugs and fill each with a soulition of marvels mystery oil ,then replace the spark plugs let it set for aweek or so then remove the plugs and try to roll it over. You might also try pouring some though the exhaust and letting it set at the same time might help with any stuck valves.
Karl Bader
07-03-2001 04:53:56
What sort of advise are you looking for?
Thanks,
Karl
Mike P
07-03-2001 05:38:06
 Re: Re: 2010 Gas stuck engine in reply to Karl Bader, 07-03-2001 04:53:56
How to un-stuck the engine. Thanks
Tom in Mo.
07-02-2001 18:54:59
This is wide open. I have a 2010 that was left out for a year or two without a can. Ended up replacing the sleeve plate ($450. + labor) rings, head job, gaskets, etc. From stuck, yard ornament to servicable, parade duty tractor was $5500. +- including cost of stuck machine and tires. Does it have remote hydraulics, wide or narrow front, what size rear rims, steel or cast iron rear rims, what year (serial #)?
Mike P
07-02-2001 20:08:05
 Re: Re: 2010 Gas stuck engine in reply to Tom in Mo., 07-02-2001 18:54:59
It's a wide front. i'm not sure if the rear is iron or steel but they can move in and out if that helps. As far as remote hydo I think it used to but was removed. the S/N begins with RU23XXX. Thanks for the reply
Tom in Mo.
07-02-2001 20:20:09
 Re: Re: Re: 2010 Gas stuck engine in reply to Mike P, 07-02-2001 20:08:05
Yours is a '62. At serial No. 29000 they made several improvements, especially in the hydraulics. It's your call whether to get into it or not; you could put your tractor money to better use. I redid mine because it is a late model (1965) and runs on LP so it is relatively rare.
