12-Volt electrics on 1951 Model B
Bob Weber
07-06-2001 16:48:55
I bought a Model B that the previous owner had converted to 12 volts (well, he put a 12 volt battery in it and an alternator, but never bothered to wire in the alternator). My question concerns the ignition coil. Can I run the original 6-volt coil, and if so, should I wire a ballast resistor in series with the points to keep them from burning up? Thanks for your responses!
Clooney
07-06-2001 17:30:37
 Re: 12-Volt electrics on 1951 Model B in reply to Bob Weber, 07-06-2001 16:48:55
Bob, if that tractor has the Wico distributor 12 volts will definitely harm it. Yes, a ballast resistor would be a good idea no matter what distributor it has & you will be able to use the 6 volt coil. Keep in mind most alternators try to hold the system voltage at about 14.2 volts.
