1949 Model A adjustments and service manual
charlie segrave
07-07-2001 08:25:28
Will a service manual tell me how to adjust my clutch so the lever will not pop back? I have to keep my foot on it keep the lever forward. Will a service manual have the info for fixing the hyd. lift from leaking down? Who has the best service manual?
Clooney
07-07-2001 09:05:12
 Re: 1949 Model A adjustments and service manual in reply to charlie segrave, 07-07-2001 08:25:28
Charlie, the service manual will tell you how to adjust your clutch but you will probably have to figure out what is worn & causing your clutch to pop back on your own. You probably have worn "toggles", "dogs", "adjusting bolts", or "sliding collar", or they all have wear on them adding up to the toggles not going completly over center. The service manual will also tell you how to find & repair the leak down on your power-trol, more than likely it is the piston seal. John Deere has the best manuals for your tractor.
