43 B Push Rod Tubes?
Joe Fabregas
07-09-2001 16:10:39
I read the push rod tubes could be replaced using the correct tools without removing the head. Didn't say what the tools were or how to do it. Anyone done this procedure on the tractor? Thanks! Joe in ny
luckydog
07-10-2001 06:16:36
 Re: 43 B Push Rod Tubes? in reply to Joe Fabregas, 07-09-2001 16:10:39
Joe--You can do this but be very careful. Think you can take a small punch or chiesel and get under the lip of the push rod tube then pull it out. Takes some work but maybe it will save you some time. It does have a tappered end that goes in first. Take time and you can do it. luckydog
haci yilmaz
07-10-2001 00:18:23
Dear Sir,
We introduce ourselves as GENMOT CRANKSHAFT MANUFACTURING CO. which is
manufacturing crankshaft since 1987. Now we enlarged our manufacturing crankshaft since 1987.Now we enlarged our manufacturing field and established genmot group ltd.
Genmot casting factory, Genmot machining factory and genmot automotive marketing-
trading co. ltd.we have approximately 162 kinds crankshaft in our production line from 1 cyl. to 8 cyl. we sell our products 55% to domain market and export 45% to foreign market such as Italy, Belgium, South Africa, Mexico, Sudan, Greece, Spain, USA, Germany,
England, Danmark, Algeria, Maroc, Irak, France, Iran, China, Hungary, Argentina, Chile....
GENMOT CRANKSHAFT FACTORY Certificated with ISO 9002 certificate from
RWTUW-GERMANY.
However , we export the spare parts of Tractors , Trucks, Cars , Bus and Compressors (air & water)
(piston, cylinder liner, pistonring, gasket, valve, valve guide, valve seat ring, engine mounting, rubber mounting, air brake system, clutch systems, adjustable arm, hydraulic midle tension arm, power steering conversion kits with bypass system, gear pump, tandem gear pump, door rubber, window chanels, trunk lid rubber, glass rubber, stell whell rim, driving lights, headlight, reflector, glasses, suspension parts,chassis - body parts, steel wheel rim, complete radiators ..... ..)
We are ready to serve you about all the spare parts , If you are interested in .
BEST REGARDS
Mr. HACI YILMAZ
www.genmot.com.tr
fax: +90-332-238 57 76 NOTE :AS WE ARE GENMOT BOUGHT THE CRANKSHAFT LINE OF MERCEDES BENZ IN 2001. WE CONTINUE TO PRODUCE VARIOS CRANKSHAFT WITH HIGH QUALITY AND ECONOMICAL PRICES Tractor Groups :
DEUTZ, FIAT, FORD, IHC, JOHN DEERE, MASSEY FERGUSON, STEYR, UTB, ZETOR,
LEYLAND-BMC, MWM.
Trucks Groups :
BEDFORD, BERLIET, CATERPILLAR, CUMMINS, DAF, DAIMLER BENZ,
FIAT-IVECO, FORD, HANOMAG, ISUZU, KAMAZ, LEYLAND-BMC, MAN, PERKINS,
RVI, SCANIA, SAME, VOLVO.
Car Groups :
ALFA ROMEO, AUDI, CITROEN, FIAT, FORD, ISUZU, KIA, LADA, LAND ROVER,
MERCEDES BENZ, MITSUBISHI, NISSAN,OPEL, PEUGEOT, RENAULT.
Other Engines :
DAHL, DEUTZ, HANOMAG, HATZ, JEANBACHER, KNORR-BREMSE, LISTER, LOMBARDINI, PETTER, WESTINGHOUSE..... ...
John T
07-09-2001 18:57:16
Joe, its been a while, but I could swear they had one larger end and it went into and was driven in from the inner (piston) side of the head towards the outside of head????? Anyway, it helps to place the tubes in the freezer before you insert them and we used the exact size of a bushing driver and it worked well. Maybe we will both learn something here if what you say is posible. Ol John T in Indiana
Joe Fabregas
07-09-2001 19:22:42
 Re: Re: 43 B Push Rod Tubes? in reply to John T, 07-09-2001 18:57:16
1950 Motor's Truck & Tractor Repair Manual, page 773. 'Note that the rear end of the of the sleeves are about .002" smaller in diameter than is the front end and this smaller end goes toward the crankcase...'...'NOTE--If no other work is required, sleeves may be removed without removing the cylinder head from the tractor. After removing rocker arms and push rods, pull out the sleevs with a suitable puller.' I'm pretty sure mine are leaking and sure would like to find a simple way out. Thanks, John T! Appreciate the input. Joe Fabregas
bob weber
07-09-2001 20:32:57
 Re: Re: Re: 43 B Push Rod Tubes? in reply to Joe Fabregas, 07-09-2001 19:22:42
Joe, it'd be a neat trick to be able to do that, but I'm not sure what a "suitable puller" would be! They do go in with the small end towards the crankcase, so really only the last 5/8 of an inch or so needs to be pressed in. I just replaced mine, but pulled the head to do it. I wasn't sure of the condition of the head gasket, so pulled the head and then had the valves and seats touched up as well. And with the head laying on the workbench, it's real simple to replace the pushrod tubes. Now I know it's good to go for another 50 years.
