1949 B axle seal
Kemper
07-10-2001 19:03:33
I have a axle seal leaking on a 49 B,can anyone tell me how big of a job it is to put a new one in?
Russ
07-10-2001 19:54:17
 Re: 1949 B axle seal in reply to Kemper, 07-10-2001 19:03:33
Pretty big, Remove wheel, Remove Axle, there is a dust cover on the outside, but that will not fix the problem. helps to run oil level a little low, and don't park on the side of a hill. Consult repair manual for all the details. Your first problem if wheel has not been moved for awhile is getting the wheel off. Russ
Chuck
07-10-2001 20:48:46
 Re: Re: 1949 B axle seal in reply to Russ, 07-10-2001 19:54:17
I replaced one a 50 B, took better part of a day, had to swing the powertrol off, remove the bull gear, axle (after removing the wheel...the wheel is the biggest job.. you'll need a boom or a couple of guys to handle it...if it gets over center be sure to jump out of the way or you'll become a pancake....I wouldn't recommend changing as my new seal also leaked....just put 140 weight oil, leave low and put about 5 can of stp in rear end....
