Need info on sleeving a JD 420T
jm
07-15-2001 21:11:16
I have a 1958 JD 420T. In the process of overhauling my tractor I noticed a small hairline crack in the #1 cylinder wall. I was told (from this message board) that I should either find another block or sleeve the cylinders. I would like to salvage the block and sleeve the cylinders if possible, but I am unsure of how this is done. The engine has been rebuilt before, at least once, as I removed .040 oversize pistons from the block. I was thinking they would have to seal the crack in some way, then bore the cylinders out and press the sleeves in. Then I would probably have to go back to standard size pistons. I would like to understand a little bit more about this before I go speak with someone about doing this work. Any advice or insight would be greatly appreciated. Thanks.
Gpower
07-16-2001 15:29:24
 Re: Need info on sleeving a JD 420T in reply to jm, 07-15-2001 21:11:16
You can get it back to factory specs with new sleeves. The crack is not a problem, they will bore out what they need and press the new sleeves in. Take them your pistons if you want and they will get the sleeves to fit the pistons. I do it all the time. Good luck
