4010 lp
jim
10-14-2003 18:34:11
Saw a 4010 lp the other day. It had a nonadjustable front axle, rowcrop style flat top fenders adjustable rear axles and 3 point. What is this? Supposedley this front axle has been on the tractor since new, Would this be considered to be a wheatland tractor?
Thanks
T213R
10-15-2003 07:23:54
 Re: 4010 lp in reply to jim, 10-14-2003 18:34:11
Look at the serial number plate. See the "handle" I use? That is the code for a rowcrop 4020 diesel. A 4010 should read something like T21 if it is a rowcrop or T22 if it is a standard. The third #, the #3 in T213R indicates fuel type, which wasn't included with 4010 serial numbers. If the tractor has a third #, 1=gas, 2=lp, 3=diesel, it is a 4020.
Rob
10-15-2003 06:29:13
Sounds like a wheatland 4020 that someone put row crop fenders on.
JW
10-14-2003 20:13:58
Wheatland, Western, or Standard depending on where your at.
