1952 model A fuel problem
ron sharpe
07-25-2001 18:38:44
I just purchased a john deer 1952 model A and I am experiencing some fuel starvation problems. I noticed that there is no manuel fuel shut off valve,and that one of the previous owners has rigged a little metal strap across the top of the glass sediment bowl to hold down a little valve of some sort. I then also noticed the fuel problem after i touched the metal strap,now the valve isn't staying down. Could this be my problem? If so how could i fix it the right way.Thanks Ron Sharpe
Clooney
07-25-2001 18:59:28
 Re: 1952 model A fuel problem in reply to ron sharpe, 07-25-2001 18:38:44
Ron, it sounds like you have the oil pressure operated automatic fuel shut off offered for the late A. It is supposed to work with engine oil pressure operating a diaphragm to open that little valve you see. For some reason the oil pressure isn't opening it & someone has rigged a strap to keep it open. If you have an oil line running to it & it has oil pressure then it probably needs new diaphragms (2) used. You can either repair that auto shut-off (parts are still available for it) or just replace it with a manual shut-off.
ron sharpe
07-25-2001 20:24:16
 Re: Re: 1952 model A fuel problem in reply to Clooney, 07-25-2001 18:59:28
"Clooney" Thank you very much. Ron Sharpe
