Carb problems on 620
Jeff
07-29-2001 16:16:18
Float will not cut off flow of gas on this tractor had it to the local JD dealer. This carb does not have the replacable seat in the carb. Service manager says carb is junk have to get a new one. Tractor runs good just uses way to much gas 5 gallon an hour if working hard. Can someone out there fix this
clooney
07-31-2001 04:02:33
 Re: Carb problems on 620 in reply to Jeff, 07-29-2001 16:16:18
Jeff, if it runs good it probably isn't the needle & seat. Try adjusting the load needle in some until it doesn't want to pull a load clean then back it out just a little & see if your economy improves.
