Has any body ever heard using a bush hog with a J.D. Model b
Jim
08-01-2001 14:18:48
would it work
TractorNut
08-05-2001 13:10:20
 Re: has any body ever heard using a bush hog with a J.D. Model b in reply to Jim, 08-01-2001 14:18:48
I have a 41B w/ 3 point and use a 72 inch Model 272 JD Finish mower. In heavy weeds it wont pull it. As a finish mower it works great but it's not a brushcutter. Depends on what you are cutting I guess.
ZiggyStardust
08-03-2001 08:48:35
Jim,
I have used our '49B to mow our pasture with. It can handle a 5ft hog in grass that is mowed often. I have tried using a 6ft mower and the tractor really has to work and wont make it through any grass that is thick. If your going to mow grass that is high with brush, I would recommend using a 4ft mower. Hope this helps
Ziggy
KWB
08-02-2001 15:10:30
What year is your B? The old unstyled B's are going to be low on power for a bushhog. A late gas B should handle a 5 foot OK. There is quite a bit of difference between the various models of B's in horsepower and utility. That's my opinion, anyway.
Jim
08-02-2001 15:17:23
 Re: Re: has any body ever heard using a bush hog with a J.D. Model b in reply to KWB, 08-02-2001 15:10:30
It's a 41 b in real good shape
Chuck
08-02-2001 07:46:19
I have had several B's with 3 point hitches and recommend a 5' bushog. Tractor is only 28 H.P. and to clarify matters, you need both a slip clutch on your bushog and an override clutch. Override goes at the tractor and the slip clutch goes on the bushog. Just rebuilt a transmission for a man that couldn't afford a 60 slip clutch. Also you want to run the engine at high speed so to avoid the stroke torque of the engine.
JIm
08-02-2001 14:20:23
 Re: Re: has any body ever heard using a bush hog with a J.D. Model b in reply to Chuck, 08-02-2001 07:46:19
what is a slip clutch and where can i get one . I have just bought 10 acres mostly pastureand i can almost mow it with my rider but it would take days but i have a jd b and i really don't want to sell it to buy one that will mow my property so my question was what is the best way to mow it ?does a bush hog take more horspower than a finishing mower ? thanks for all the help. Jim
Bill Pries
08-02-2001 07:24:23
I have an 84" finish mower on a '49 A. Seems to work. Biggest lawn mower in the neighborhood!
JDMO
08-02-2001 05:10:13
I've used a JD 127 mower, 5 foot, with a B and have not had problems.
Russ
08-01-2001 19:37:15
I pull a 6 foot, with my 50 B. Does well in small brush,rose bushes,weeds, not well in matted grass. Creeper gear only, and keep blades sharp. Russ.
Russ
08-01-2001 19:51:24
 Re: Re: has any body ever heard using a bush hog with a J.D. Model b in reply to Russ, 08-01-2001 19:37:15
P.S. be sure and use an overrunning clutch on the PTO. Russ
Jason
08-02-2001 15:57:46
 Re: Re: Re: has any body ever heard using a bush hog with a J.D. Model b in reply to Russ, 08-01-2001 19:51:24
I think i would use a sickle bar unless you are trying to be fancy.
