Where is the serial number on a JD A
Joe
08-12-2001 07:46:33
Thanks
Russ
08-12-2001 10:04:44
 Re: Where is the serial number on a JD A in reply to Joe, 08-12-2001 07:46:33
The Style ones are under the Mag. The un-styled A'S 1938 and older are in front of the flywheel. Russ
RON SHARPE
08-12-2001 08:45:58
IT'S UNDER THE DISTRIBUTOR RIVITED TO THE CRANK CASE.
Dave K. (Fl)
08-12-2001 08:52:30
 Re: Re: Where is the serial number on a JD A in reply to RON SHARPE, 08-12-2001 08:45:58
There is (should be) a metal tag rivited to the frame under the magneto. This will have the serial number stamped on it. In some cases these tags have been removed, tractor generaly sells cheaper with no serial number,
Dave
